Hello .
I have a Fuji xt2.
I am trying to shot video using a vintage lens but my camera won’t record footage (with my vintage lens)
I have set my camera to shoot without a lens (no problem using the vintage lens for stills)
I have a m42 adapter and Pentax 55mm F2 Super Takumar prime lens
has anyone experienced this problem and found a solution?
