Missing RAW files
By jakabasej8 · Posted
To prevent accidental touchscreen mishaps, check your camera's settings—there's often an option to disable touch control during shooting or playback. That could save you from some future headaches. -
I'd definitely recommend a firmware update as a first step, and if that doesn't work, try a different memory card. -
By maximkrykovich · Posted
I faced the same problem today. I don't know what to do!? I live in Russia, there are no service centers. -
The fans are flying in to get good seats for the next round of dragonfly gymnastics...
The competitor is not ready, apparently something on the equipment is not right... Everything is now sorted, ready to go... And THERE IT IS!!! The Handstand!!! Of course with that many arms, how hard can it be? -
By Ben Bishop · Posted
You mention that you worry you'll be criticized for not knowing basics. I won't; I'd suggest that you might simplify your approach. If you want crisp waves in low light conditions then you'll need a higher "speed" than 400 ISO. I shoot higher than that on an X-H1 and the images are noiseless for my purposes. I'd give up ND filters and high apertures and instead go with higher speed and lower apertures. I don't just use exposure compensation - I depend on it. But then again, I usually shoot off the hip. If I was shooting off a tripod I would take an ambient light reading with a meter, subtract 1⅓ or 1½ and go from there. I also don't know if this is a scene you can return to regularly or if it's a travel treat. Happy shooting.
