I shoot RAW with my Fujifilm X-H2S and X-T3. My colour profile of choice is Provia. When I import into Lightroom, Camera MAtching profiles are selected and I haven't got an issue. Recently, I bought DXO Raw 4 as I like the results from high ISO images better than LR. However, upon re-import from DXO whether in DNG or TIFF format, the colour profile defaults to Adobe Colour. Does anyone know how to re-assign the colour profile or to be able to import Fuji colour profiles without affecting the results of the DXO conversion?
