Hey everyone,
I'm torn between getting a lens that I'll be using a lot in the future, or if I should just make-do with my current loadout.
Do you think 23mm f/1.4 + 35mm f/1.4 combo would be enough for a street style* fashion photoshoot (for eyewear) or do you think I should go for a longer lens? I'm considering purchasing 16-55mm f/2.8 but, you know, that glass is a tad expensive.
Attached photo is from a trial shoot we made today. My model (actually the shoot's stylist) has no makeup. Image is unprocessed, obviously. Taken with the 35mm. It was really tricky get myself out of the frame because the glass is reflective.
Plus, I normally shoot reportage/documentary photos in available light conditions, so a sturdy lens like the 16-55mm really could come in handy in the future.
* It's not going to be an ordinary show-product-in-a-head-shot sort of photoshoot. Think sneaky street/candid portraits — but with products. Plus, my models don't have a problem with working close.
(I wish 90mm f/2.0 were out, I'd get it in a heartbeat. I don't want to buy 56mm f/1.2 at the moment — I know it's great but it's slightly older, I've heard that its autofocus is less than stellar and has got no WR. And if I were to invest in a portrait lens, I'd prefer to work with 90mm's tighter focal length)
Cheers,
Cihan
Example
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
