Hi everyone, I am new to fuji cameras. I bought an XH-2 six months ago. I switched from Sonya7s2 to Fuji XH-2. When I shooting photograph IBIS performs very well. But when I shooting handheld videos, something looks weird i think. IBIS absorbing the micro movements but when I try the swipe the camera or walk slowly the movements looks obvious. I am not sure that is there any problem with my camera or is it normal. What do you think about it.
I tried with 30mm macro - 16-80 F4 AND XF 56 1.2 WR ( IBIS+OIS option turned on, DIS-IBIS BOOST Off)
