Hi.
I have a GFX 50S and do a lot of shooting in studio with tethering. I have a TetherTools micro USB to USB-C cable, but it rubs me the wrong way that the cable is angeled upwards when connected. I haven't been able to find the same cable facing downwards, is there a reliable tethering cable that does this?
Thanks.
  • 8 months later...
On 4/30/2024 at 8:23 AM, Pedro Marquez said:
I can recommend this one from Mathorn brand:
https://mathorn.com/en/tethering-cables/tethering-5m-2/mtc-531/
It works nice with my GFX50s - see the video
Hey Pedro !
so I just bought the cable you posted above and weirdly - with my GFX50S the angle (when inserted) is exactly like the OP ! … UP !
can you confirm which way your port faces ?
thanks
Tim
    • It appears that Apple now (at last!) fully supports FujiFilm Lossless and Compressed RAF files. In the latest updates of MacOS Tahoe 26.2, iOS 26 and iPadOS 26 compressed files are supported in Finder/Files and the Photos app. Good news for those of us with Macs and iPads.
