Oldtimer Meeting Donauwörth/Germany
Hey Guys,
just came back from a 2CV Raid where we drove to a local Oldie Meeting (with 15 2CVs :-)
want to share some Pics I took and edited them in LR based on Samuel Zellers presets, think this 70s look fits to the cars...
What do you mean?
all taken with the X-T10 and the 18-55
28822493294_f195994f65_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
29158005180_8441477dee_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
29158009890_7ce650576f_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
28822504034_98277632f1_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
29366507881_bcfd392a03_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
29158017650_25c589f669_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
29157998630_45a5cbd6d4_h.jpgOldtimertreffen Donauwörth 2016 by Fabian J., auf Flickr
some more to come in the next days...
thanks for watching!
