After updating my firmware, 3 out of 4 of my saved recipes caused 0.5s lags per shot and when I looked for the problem, putting values in Clarity is the main issue. Has anyone else experienced this? What's the solution? Can you also by any chance revert back to an older firmware?
Edited by jeus_saaa
