Having Trouble Downloading FujiFilm X Webcam on my MacBook
I am under the impression that I have to have FujiFilm x Webcam AND ManyCam in order to even get the camera to show up in OBS. I have a MacBook Pro and am on 10.5.1. I talked to Fuji and they were pretty much no help, they said it was working on their Mac in office.
TLDR; Every time I try to download FF x WC it tells me there was an installation error... I am very frustrated and just want to YT live stream from my camera. Thanks so much!
I have a FujiFilm x-t30 ii btw.
