The auto-transfer feature keeps getting stuck on uploading the same 1 image and then disconnects from the camera. The camera screen then freezes with the on/off switch function not turning the camera off. The only way to turn the camera off was to remove the battery.
It was working fine after I uploaded 300 images from a previous memory card. but this batch of 500 images keeps getting stuck after uploading the first image and then freezes the camera.
I'm also having the same problem since the last firmware update. Camera remote app connects and then transfers only 1 photo. Camera also freezes in a connection mode (green light constantly on).
It's very frustrating.
