Hi everyone. Hoping you can shed some light as I have tried everything I can think of!
I have an issue with my X-T30 ll. Suddenly stopped recognising the ‘aperture lock’ signal from my lens. Fine one minute, not the next.
The LED screen has stopped displaying shooting mode symbol (ie S A M or P) but the current shooting mode is still visible in Qmenu
- I can still select and use aperture priority and manual as normal - ie the camera recognises the actual aperture selected - and I can adjust it via the lens ring - but it doesn’t recognise the ‘A’ -locked- position which is required for Shutter priority
- when I try to select shutter priority - ie with a shutter speed selected and the aperture ring locked at A - it tells me (in the Q menu) that it is in Manual mode, even though I can’t change the aperture using the aperture ring (ie the aperture IS actually locked.)
- when the aperture ring is in the A position, I can’t change the aperture using the aperture ring - which is as it should be.
I have tried three different lenses and I have tried another X-t30 body - they all work fine. So it’s definitely something to do with the Mark ll body.
I’m travelling in remote northern India atm with very little internet and doing this on my phone- a bit tricky! Hoping someone can help! Thanks I’m advance.
