Hi guys,
This may very well be a non-issue, but I recently purchased a new x100v, and I've noticed that when using the OVF, if I move my eye ALL the way to the right side of the viewfinder, a purple color/fringe bleeds into the frame. I can't tell if this is just a reflection from some internal components of the viewfinder, but wanted to check that this is normal, while my camera is still under warranty.
It's not something that's affecting my daily use, but I noticed it when moving my head/eye to the far right of the viewable area and want to know that it's not an error that might get worse with time. If any x100v users out there could try the same thing and report back whether they see any purple colour in the far, far right of the OVF, that would be hugely appreciated 🙏🙏
Thanks in advance,
Raphael
