X100V huge issue, stuck in "pair with smartphone" mode
As BobJ notes, it probvably easier and better to stich multiple shots when you process the photos. Lightroom is easy and provides very good results. I'm sure there are other photo editors that can do it too. You'll get a bigger and better file from stitching multiple raw files.
In the Camera RAW module, Profile, Browse, look for the Fuji film simulations... I'm assuming you are already doing that, as it sounds like you see other Fuji profiles, I don't know why the ones you want are missing.
Factory reset of the camera. Repeated cycling of the flash beween up and down position. It's quite likely a fault, the microswitch or other sensor for flash position has failed or is jammed/stuck. You might need to send it in for repair.
More modern phones with USB-C seem to be able to do backups from camera/card reader to external USB drive with no need for a computer. I haven't tried this personally. https://petapixel.com/2025/05/11/no-laptop-no-problem-how-to-back-up-photos-in-the-field-with-your-smartphone/
How about using a phone or a tablet? This is probably the fastest and easiest way to do it.
