Hi everyone. I am ol canon user and recently bought x h2. And be aware that while all condition almost as the same, fuji use 3 times slow giving the same exposure. Be sure i check metering time, focus lengt, under the same light and object, aperture. I use canon 18 55 and fuji 16 80. I know all diffrent cencor and objective but difference is much more then i guess. Especiallty under little low light this will be problem cause of flu picture. I change light metering spot multi etc but also result did not change. Anyone can help me if any experiances have to compared x h2 and the other brands the same condition as possible as. Thank you
