AHA!! An answer... what I had done was hold the MENU button for too long and I was locked out. So the answer is to hold the MENU button for 3+ seconds and the lock comes off and the Q button works again! (What a stupid design feature having a lock function there IMHO!)
Yes, that is correct.  If there is a small yellow images of the camera with a lock next to it on your middle right screen, it is because the menu has been locked.  This will cause the Q menu to not appear when the Q button is pressed - even if the Q menu has been assigned to the Q button.  To unlock the menu, you need to hold down the Menu/OK button for 3 or 4 seconds - until it says the yellow locked sign goes away.  I had to try this several times, but it eventually worked.
