pocket wizard connect to Fujifilm X-H2?
Has anyone found or successfully adapted a walking pole as a monopod?? I’m off to Chile and need to keep kit small and light but expect high winds. X-pro2 user. Thanks
thank you, I just bought this from a market place, the pictures from the store did not show that particular micro scratch. After asking this and showing the picture above to seller, he said that it is not micro scratch, instead it is micro dust from behind the lens..hmmmmmm
To directly answer part of your question, the voltage is safe and the current seems sufficient. The images of the LB-50 look okay, but to be certain it will fit, you need to check the dimensions closely, the corner notch in particular. Why not pick up a couple of the NP-50 replacement batteries? They are readily available and low cost (I know you said budget is not much of a consideration). That way you will have plenty of back up battery and use the spare change to get another storage card.
Hi! I'm new to the work of Fujifilm, please please bear with me. I bought a used X-A3 for an every day carry. I've been learning the functionality through the manual and Youtube where I can. I've been trying to shoot in Manual (M) mode but when I put it in this mode the camera displays 'P'. If I have custom settings saved it will shoot in the custom settings. The same happens when I try to shoot in Shutter Priority (S). The Aperture (A) mode works fine and so does the Program AE (P) mode. Any thoughts out there as to the reason for this. "User error" is an acceptable answer.
Hi all, I was looking for a battey replacement/upgrade for my X10. Would the Lectrosonic LB-50 1000mah work here? What are you guys using instead? Budget isn't too much of a consideration, just wanted a reliable upgrade. Thanks!
