Hi folks,
Finally, after a long wait, I had the opportunity to meet and take pictures of the beautiful and enigmatic Little Owl (Athene noctua), one of my favorite European birds, and probably the cutest bird I’ve ever seen.
This little fluffy raptor measures around 21 cm in length with a wingspan of 55 cm (both male and female). Its weigh is about 170 grams. Its plumage color is brown and grey spotted with white. Its big yellow eyes stand out giving the bird a funny frowning expression as you can see in my new article on my website: Come check it out here: Little Owl Photo Hide
I show you one of the pictures of the article. You can see the rest of them on the article.
Little Owl - XT-1 + XF100-400mm f4.5-5.6 LM OIS WR
Edited by Jose Carpin
