When an HDMI device is connected to the camera.
Then I pressed the play button to enter playback mode to review the images taken.
In playback mode, The contents of the camera display will be shown only on the HDMI device, and the camera display will be turned off.
How to make the playback shown on both camera screen and HDMI device?????
The scenario is I'm using an HDMI recorder (one without monitor) to record the camera screen of what I'm doing.
But I can't playback and review the image when HDMI is connected since it go to HDMI output only and not shown on the camera screen.
