Hey guys, this is my first post here.
Yesterday I took my x-pro2 and the 50-140 to the zoo to test the combo and it did not disappoint whatsoever. Well, it did scare for a few seconds because I got the "turn camera off then on again" message once.
https://flic.kr/s/aHskxA873H
I'm not sure how to embed the images so until I do that's the link to the album. I hope you like it!
