    • It appears that Apple now (at last!) fully supports FujiFilm Lossless and Compressed RAF files. In the latest updates of MacOS Tahoe 26.2, iOS 26 and iPadOS 26 compressed files are supported in Finder/Files and the Photos app. Good news for those of us with Macs and iPads.
