Hello, Im looking for a bit of help with my shoe mount (Ef-42) with my Xt4. I seem to have lost the TTL option in my flash setting since attaching my new flash. I don't know if I've got the camera on a setting of some kind but whether the flash is mounted or not, I don't have TTL in my setting anymore - only M or off. Does anyone have any knowledge on what's happening?
Thank you!
