Hello,
I just purchased the XF 100-400mm lens for my x-t4. When I reach a focal length of 300+ it asks my camera to turn off and on. Is this a setting issue, or an issue with the lens? I am relatively new at this level photography and type of camera, so please excuse me.
I have this lens and find that at f11 at full extension and a distance of about 20m there is very little depth of field. Frustrating when there is a bird and some branches.
I called up a depth of field calculator and there is about 60 cm dof.
I need to be more careful in my focus settings.
