I have this problem when i use a flog , what do you think?
color problem?
Recorded with H2s at 29.97fps in H265 4:2:0 at 10bit at 360mbps
6.2k latest firmware and Oficlal F-log to Eterna 1.23
Edited by jorgenaba
