Good morning, photography comrades
I am writing to you for advice as a newly incorporated amateur into the world of photography.
I would like to start in macrophotography, and for this I would need a lens that was according to the camera I own, which is a Fuji X-S10.
I would not mind moving in high budgets (€ 1000, other types of equipment included if needed) if I can get results similar to those I am looking for. Similar to this 20 photos macro exceptionnelles de dame nature | fénoweb (fenoweb.com)
Hope you can help me with this.
Thanks in advance for your help!
María
if the budget allows it, the fuji 80mm macro is unbeatable and often second hand under 1k€
with the remaining budget you could/should get a dedicated macro flash
the cheapest option would be an extension tube (or set)
mid way is the fuji 60mm, which can go to 1:1 with an extension tube
getting one of the macro lenses or an extension tube with electrical contacts would allow you to use the focus stacking feature in the camera, as opposed to going for an adapted/manual lens
lighting, however, is important in macro, so a decent front mounted flash is needed (even LED does a decent job)
