Hi all...
I've recently aquired a 1st gen x100.
Yes the og x100 and also a og Ef-x20 flash...
I've updated the firmware to 2.1 but however I'm unable to use the flash on ttl.
It just keep flashing amber on the test button and when I can shoot, it just fires full power.
My auto iso is off and I'm on aperture priority.
Is there any way that I can check or ensure whether the ttl is working
