Recent trip up the BC Coast
brijcharan
Hi there.
Thought I'd share a shot from my recent trip up Vancouver Island last weekend.
Fuji x-t1, Fujifilm XF 16-55mm f/2.8 R LM WR
  • 5 weeks later...
    • Hi all, I notice that there are some focusing sound on my XF33 despite it being said as completely silent in many review. The focusing sound is kind of like stepping motor sound, and it only appears when I’m shooting photo. I try shooting near and far away and there is sound. However, it is completely silence when I shoot videos. Is it normal or do I need to change some of my setting? Or am I just getting a not too good copy haha. please assist me with the matter guys! Thanks!
