I want to create a custom setting for my X100t in “[EDIT/SAVE CUSTOM SETTING]” but can’t change the R and B setting of the white balance. When I select “white balance” and for example “color temperature” & click “menu/ok” i can change color temp to say 4300k but can’t make any other changes. How do I change the R and B to for example -3?
