Depends what lenes you have for your X-E2 and how much gear you want to carry. IMO the X100T which easily fits in a large pocket, makes you think about composition more with its fixed focal length lens. As long as you don't spend the trip wishing you had the wider or longer lens with you, you will zoom with your feet, as Robert Capa said. A great war photographer long before zooms were invented.
Enjoy your trip.
Do you own both of these cameras or are you still considering which one to buy ?
Lisbon is on a river estuary, it has hills and some vast open areas in the city, so depending where you go you'll probably have the opportunity to shoot great landscapes/cityscapes besides the normal street shots. The X100T is a bit limited when it comes to wide angle, so maybe you should consider taking the X-E2 with a wide angle lens or zoom. If you already have an X100T, the 0.8x wide conversion lens could also be an option although it isn't nearly as broad as most wide angle lenses in the lineup and you could be frustrated by that missing tiny bit of width.
As FujiMike points out, the X100T remains more pocketable and convenient so it would definitely my main camera that I carry around my neck or in a coat pocket everywhere, but ideally I'd also have the X-E2 in a camera bag close at hand.
