Aspect Ratios of Framing Guides
By MARRIEDGUY9 · Posted
three photos from the bayside near Dewey Beach, DE.......experimenting with the 8mm 3.5.......just before sunset and a couple more as it got darker.Welcome, dear visitor! As registered member you'd see an image here…
Jefferson County, Kentucky, USA -
Hi, Same issue here since the firmware update. I'm on ColorOs (android 13) on an Oppo Find X3 Lite for reference, it really is a shame if they do not plan on releasing an update. The only solution I see for now would be to downgrade the firmware to the previous version, using some shady hacks, but not sure how safe it is.
Just linking here as there may be more exposure (pun intended:))
Hi Folks, I'm trying to find out why my X2T-f actually has the opposite problem when on the hotshoe of my XT-3. Most people complain about it forcing TTL mode. Mine will NOT work in TTL any shape or form. TTL is dead - The camera flash section only shows manual and no power setting is available in that section. I've only ever been able to set my 2 flash groups to work in manual and actually I cannot even remember if TTL ever worked. I just have to set the correct power settings. When a flash is set to work in TTL mode it fires weakly and simply doesn;t respond to the conditions - not surprisingly as the camera is already telling me this will be the case I only realised this when I bought an XT3 trigger and it forced only TTL mode as soon as I attached it and turned it on. Speed is immediately set to 60 in AP. That's no problem to me as it works fine if I go manual on the camera and set speed to whatever I need slower or faster, TTL works flawlessly in manual or AP mode and I realised that my X2T must be faulty (perhaps since I bought it?). I've spent hours looking in the menu for an answer. I even reset it, reverted to firmware 1.1 and then back to 1.4. Nothing alters this behaviour, there is no TTL and the camera doesn't recognise it. So before I deem this faulty and bin it, or just keep is as a manual backup, I thought I'd just ask here to see if anyone has had a similar problem and found a way to make it work.
