Hi
Can someone please let me know how to quickly switch between AF and MF with this X-S10 model. In terms of some of the previous models, there is a physical switch that we can toggle back and forth.
I am asking this considering that I have two lenses one Fuji (auto) and Third party (Manual) - so wondering what is the best and quick way to do this. Also while using the fuji lens - how I can switch to the manual focus at times.
thanks
S
@cpX thanks for your reply. One more question, is it possible to assign multiple functions to a single Fn key. For example, the White Balance Fn button - is it possible to add more Fn to the same button apart from what it is already doing? Sometimes, I feel certain default actions are ideal for me. 😁
Hi @cpX thanks for the input, yes I read through the manual. There is no hint of this. Hence my post.
I will keep exploring. Which button would you use to assign 'Preview DOF button' to if you wanted to. If multiple assignment was possible, I may probably use the fn button next to EVF to switch between WB and 'Preview DOF button'.
thanks again
S
