Lately, I've been noticing a ton of red and/or cyan patches showing up all over my raw footage. Originally, I though it was from Premiere Pro but after rewatching my footage on my Fujifilm Xt-4, I determined that it's from the camera itself. Does anyone know how to fix this?
