XF 100-400mm lens w/o 1.4 Converter with X-H1 continious shooting
Hi folks of X freaks,
I have been using Fuji X from the beginning in 2012 with my first X-pro1,a genius camera for me as an old Leica M Shooter. Meanwhile for longer telephoto I bought a XH-1  and this lens
3 years ago. I took some shots in a natural resort parc in Alsace/France. The comb of this lens and X-H1 at high speed was amazing.
