About one month ago my X-T4 started acting up. First I started getting a "Turn off the camera and turn on again" screen once in a while (see attached). Now I get it often. Then, the AUTOROTATE PB stopped working. Now the ELECTRONIC LEVEL doesn't function. I've owned half a dozen FujiFilm cameras over the years and never had any problems.
Any suggestions, or ideas. I'm completely stumped.
Scott
