I noticed that my X-T200 will cut off at a shutter speed of 1/125 in Auto-ISO and aperture priority, even if I set the minimum shutter lower and there is still room for higher ISO. Anybody else with this issue or a solution? I'd really like to set a minimum of 1/250.
