Hi,
I have XT-4. Recently whenever I try to copy videos on laptop using windows 11, it prompts me with warning that access is denied & need to contact with administrator, all the while we have all the permissions from as laptop is registered on my name. Photos are copying without any problem. Also when I try to play those videos it doesn't play either. Please advise possible solutions.
Regards,
Bilal Ahmad.
