Fish-Eye Hemi with Fujifilm 10-24mm, any experiences?
A friend of mine asked me if I knew of how this program would perform correcting the perspective of the 10-24.
Of course there are many ways to perform perspective corrections but the majority imply loosing part of the frame.
Does anyone have direct experience with using this software ( or Photoshop or Aperture) with this specific lens? Could someone share before after versions of the pictures made this way?
