Question on XT3 Video streaming/recording and black out when pressed capture button
Hello everyone,
I wonder has anyone gone through similar situation like I do, and hope to hear your solution.
I use Fujifilm XT3, connect to a remote control for "start shooting" or "stop shooting" video.
XT3 is connected with a hdmi cable and elgato Camlink 4k (which changed HDMi into USB A plug).
OBS (livestreaming software) can detect Camlink, so i could stream on youtube.
My problem is, whenever i pressed "shoot" button, the recording stopped on XT3.
However, obs/yotuube will be blacked out (no video and no sound) for almost 6 to 7 seconds.
Then video/sound returned.
I looked into the manual, but i cannot find anything related with this blackout.
How can I remove the black out so that it will keep streaming without disruption.
Thank you very much for your kind consideration!
