I’ve been importing video files from my XT3 to iPhone using SD Card adapter with no issue for several years.
now for some reason, I can’t.
So I imported to iMac on Photos app. After syncing its is now on my phone. Video plays in album but I cannot import them to any video editing app.
I’m using iPhone w most current iOS.
Please help!
