Hi there,
I'm just wondering if this is a known X-T4 issue.
I've noticed after I'm back from shooting, there will be at least a couple of files that are corrupted.
Some won't open at all - can't transfer to our hard drive or open in Premiere pro.
And some, end up being this weird vertical recording
Sample photos below (attached).
Our second shooter shoots with a X-t4 as well and we both notice that we have the same issue.
We are using Sony M Series SDXC UHS-II Card 128GB, V60, CL10, U3, Max R277MB/S, W150MB/S
Thanks,
  • 9 months later...
I also had corrupted files in XT4, but they normally opened in Premiere pro. The laptop refused to transfer to my RAID or to any flash drive I found in the house. Also, I couldn't send them by email or via google share. It was very strange because I urgently needed to send the captured videos to my colleagues in the editing. As a result, I started recovering my RAID drive with salvagedata's help to restore the ability to play videos in any format and open them on other devices. After that, I sent them to Google drive and forwarded them to my colleagues. Did someone lose data when trying to play the entire video?
Edited by Xanaric
  • 1 year later...
I have read that Sony cards don't play well with the X-T4. I use SanDisk Extreme Pro UHS-I cards, since they're cheaper than the UHS-II cards, which are necessary for video bitrates over 200mbps or bursts of RAW stills, neither of which I shoot.
