I realized that the serial number is on an adhesive label, so basically it is technically possible that it is my old lens with a new label. The manual and the pouch are the same. And to be honest, it didn’t look like brand-new when I first saw it. My old lens was impeccable, so it is possible.
I am only speculating.
And when they “repaired” it, it didn’t change anything.
So, I don’t know if this lens works as it should, but it is possible that it has always been the same lens all along, just as I bought it.
@cpXThe new lens is not the same as the old one, apparently. I looked at the EXIF and the serials are different. Also, I found a photograph of my old lens. And in this one the serial was printed in the plastic of the lens. And it also had another text printed in the plastic that is not in the new one.
Would you buy that book? It would be very boring.
The manager didn’t answer my last email. So I am going to write to him again demanding an explanation from someone. Basically I want them to tell me if the lens is working as it should.
First, I have to concentrate on this. And then, if someday I finish this issue, I could write a summary in different forums about my experience with Fuji. I don't think I have enough material for a book.
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
