I have an x100T.  When I look in viewfinder a white film covers the image.
Does anyone know what’s happening?  I tried reset all to factory,  tried changing view mode, and drive, and toggled through evf - ovf modes.  No change.
thanks.  Here is pic of what I see in finder.
thanks.
Edited by Matthew Lee Studio
Add pic
  • Matthew Lee Studio changed the title to X100T -White screen in viewfinder?
  • 4 years later...
