Sports Finder crops the display by 1.25x, "reducing the picture by an amount equivalent to increasing lens focal length by 1.25x" ... says the user manual. I assume this means the 23mm lens effectively becomes 34.5mm (in full frame 35mm format). The Digital Tele-Converter on the other hand gives an equivalent to either 50mm or 70mm. Is Sports Finder therefore just another digital tele-converter, or is it doing something else entirely?
