I am currently trialling a Feiyu Tech AK2000C gimbal with an X-T4. When the two are connected via USB-C, the image on the camera LCD goes off and just shows the Bluetooth symbol, and the gimbal suggests the camera is not connected ("Camera Connected" icon is grayed out). I have turned the USB Power option in the menu of the camera to off. Is there any thing else to change? Feiyu Tech say the X-T4 is fully comatible.
TIA!
Just wondering if bluetooth connection works on the X-T4 to control start/stop recording, if you have tried it?
I once had the AK2000S model awhile back with my X-T3.  But now I have the X-T4 and looking into getting the AK2000C.  Would be nice to not have to deal with the cable to do basic start/stop recording.
