Hi,
I have a Fuji xt3. I’m having issues with the lcd. When I switch the camera on strange white line appear on the LCD, like the text has smeared. I switch the camera off and back on again and the font usually gets worst or the camera freezes. When I remove the SD cards (sandisk extreme pro 95mbs) the issue is resolved and the lcd operates perfectly. I have tried other cards but the problem still persists. Any suggestions would be appreciated
Edited by Lee329
