Would Fuji bring improved X-T4's simulation custom profile setting ('Color Chrome Effect Blue, Clarity, new Grain options, and new B&W Toning control') on X-T3/X--T30? since they share the same X-Trans IV Sensor?
Edited by Sugarcane85
