I purchased a x100t. On the command dail when changing shutter speed. I cant change it all the way from say 1 to 4000 on the command dail. Only let me change 3 up or 3 down.
I dont really know how to explain it.
On my xt3 i can change it from say 1 to highest on command dail.
