I have a video to shoot in a few days and I need the best quality possible.  In the movie settings the 200 Mbps Option is dimmed on every possible combination of frame rate and image size. I also tried 150MB/sec cards and a 300Mb/sec card.  Neither unlocks the mysterious 200 Mbps option.   What am I missing?!?!?  UPDATE: Problem solved:  in movie settings set the HDMI OUT to HD and the memory card to 4K then the 200 Mbps option is available.
Edited by Valenciadude
Update
