Hi everyone,
First, thanks for having me, I have never posted here before, and I need help.
I use an X-T3 for so much of my work, and one of the main things is to livestream with a clean HDMI. This has always worked flawlessly. Then, this morning, after working during setup, it simply went dark on the monitor.
I can send through HDMI with all the screen info, but CANNOT send clean HDMI (it sends nothing, the monitor is dark)
I have updated the firmware of body and lenses.
I have reset to factory settings
I have tried multiple monitors and multiple cords
Anyone have suggestions?
