So I just saw Viltrox released a Mark II version of their 85mm f1.8 x-mount lens. It’s being marketed as lighter than the previous version  and with a new lens hood (I presume the same quality as the 23mm and 33mm lens hood). When I asked if this model was compatible with the X-Pro 3 they said yes. I’m just wondering if anyone is able to confirm that or not. I know all their lenses thus far have had an issue with the X-Pro 3 and the lens release button.
If Viltrox says that it is compatible, then it's compatible.
The original issue was that they used a full frame lens mount which was larger diameter than the XF mount; that extra overhang was what scraped anginas the collar. They probably used a XF diameter lens mount to fix the issue.
