Hi guys!
Any of you has experience with Fotodiox's adapter for Mamiya RZ lenses?
I have purchased it a few months ago and it works on my GFX50s, but the lenses are not firing on my Mamiya anymore (unless the shutter is set on emergency/mechanic mode).
Thank you in advance.
Best regards,
William
